1. Turn locking device on back side of phone marked by the rectangle counter clockwise. Turn locking device on back side of phone marked by the rectangle counter clockwise.
    • Turn locking device on back side of phone marked by the rectangle counter clockwise.
  2. Remove battery by grabbing the sides and pulling upward.
    • Remove battery by grabbing the sides and pulling upward.
    • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws. Once all screws are removed the case will easily lift off. Once all screws are removed the case will easily lift off.
    • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
    • Once all screws are removed the case will easily lift off.
  5. With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place. With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
    • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
  6. With screw removed, gently pull the antenna outward. It should slide out easily. With screw removed, gently pull the antenna outward. It should slide out easily.
    • With screw removed, gently pull the antenna outward. It should slide out easily.
troy
1 Reputation
2 Guides authored
Clemson, Team 13-3, Benson Spring 2013 Member of Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 359
