G'z One Boulder Inside Screen Cover Replacement
    1. G'z One Boulder Inside Screen Cover Replacement, Inside Screen Cover: step 1, image 1 of 1
      • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
      • Make note that two of the screws closest to the hinge are longer than the other two.
      Ask FixBot
    2. G'z One Boulder Inside Screen Cover Replacement: step 2, image 1 of 2 G'z One Boulder Inside Screen Cover Replacement: step 2, image 2 of 2
      • Remove the two side screws.
      • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
      Ask FixBot
    3. G'z One Boulder Inside Screen Cover Replacement: step 3, image 1 of 2 G'z One Boulder Inside Screen Cover Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to remove the screen cover from the rest of the lid.
      Ask FixBot
    4. G'z One Boulder Inside Screen Cover Replacement: step 4, image 1 of 2 G'z One Boulder Inside Screen Cover Replacement: step 4, image 2 of 2
      • Your phone should look like the picture to the left.
      • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
      Ask FixBot
To disassemble your device, follow these instructions in reverse order.
Henry Johnson
4 Reputation
2 Guides authored
Clemson, Team 13-3, Benson Spring 2013 Member of Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 812
