Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓To replace a fuse for the BallyPal, follow the steps below:
Featured Document
Use an Allen Wrench to remove the two (2) screws on the main cover. Set aside.
Locate the fuses under the emergency stop button.
Remove the plastic cover over the fuse.
Gently pull the fuse from the fuse casing.
Insert new fuse into the casing.
Reuse the plastic cover to protect the fuse.
Insert and tighten screws with an Allen wrench to secure the main cover.
Fuse has been replaced. Technician should perform an Operations Check to confirm unit is ready for store use.
