Introduction
This guide will show you how to replace the microphone and speaker assembly on your Furbo Dog Camera. (Furbo:2). Replacing this component may fix any issues that you are having with your sound quality that could not be fixed by troubleshooting efforts. This guide shows you how to remove the hardware containing the microphone and speaker
Tool used on this step:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
Remove the microphone and speaker component and replace with new part
