Shop the Holiday Gift Guide
Fujitsu M2011 Keyboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
73
All Time:
762
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In order to remove the keyboard, you will need a Phillips screwdriver. This repair may be required if your keyboard is damaged or unresponsive.
Tools
    1. Fujitsu M2011 Keyboard Replacement, Battery: step 1, image 1 of 2 Fujitsu M2011 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Slide switch #1 (shown) to the left.
      Ask FixBot
    2. Fujitsu M2011 Keyboard Replacement: step 2, image 1 of 2 Fujitsu M2011 Keyboard Replacement: step 2, image 2 of 2
      • Slide switch #2 (shown) to the right and hold.
      Ask FixBot
    3. Fujitsu M2011 Keyboard Replacement: step 3, image 1 of 1
      • Pull the battery straight back out.
      Ask FixBot
    1. Fujitsu M2011 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Remove the three 4.6 mm PH0 screws in battery chamber.
      Ask FixBot
    2. Fujitsu M2011 Keyboard Replacement: step 5, image 1 of 1
      • Lift the black plate with the power button gently.
      Ask FixBot
    3. Fujitsu M2011 Keyboard Replacement: step 6, image 1 of 1
      • Remove the keyboard.
      • There will be tape on the wired connection to the motherboard.
      Ask FixBot
Author
with
Spencer Spaulding
186 Reputation
1 Guide authored
IUPUI, Team S2-G5, Baechle Fall 2018 Member of IUPUI, Team S2-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 73
All Time: 762
