Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement
  1. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Inner Back Shield: step 4, image 1 of 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: step 5, image 1 of 1
    • Remove the grey docking station port cover
  6. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: step 6, image 1 of 1
    • Gently slide the plastic opening tool along entire seam popping the clips free.
  7. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: step 7, image 1 of 1
    • Lift the shield away from the device and remove the fingerprint scanners ribbon from the motherboard.
Spencer Bacon
410 Reputation
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 15
All Time: 475
