Fujitsu LifeBook N3510 RAM Replacement
  1. Fujitsu LifeBook N3510 RAM Replacement, Battery: step 1, image 1 of 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 RAM Replacement: step 2, image 1 of 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 RAM Replacement, RAM: step 3, image 1 of 1
    • Locate the RAM cover.
  4. Fujitsu LifeBook N3510 RAM Replacement: step 4, image 1 of 1
    • Remove the screw labeled “3.”
    • The screw is not shown in the picture.
  5. Fujitsu LifeBook N3510 RAM Replacement: step 5, image 1 of 2 Fujitsu LifeBook N3510 RAM Replacement: step 5, image 2 of 2
    • Remove the RAM cover by lifting it with your finger.
  6. Fujitsu LifeBook N3510 RAM Replacement: step 6, image 1 of 2 Fujitsu LifeBook N3510 RAM Replacement: step 6, image 2 of 2
    • Remove the RAM module by pushing the securing clips outward.
    • The RAM module will then slightly pop out.
    • When you are installing a new RAM module, carefully insert it into the socket and push downwards.
  7. Fujitsu LifeBook N3510 RAM Replacement: step 7, image 1 of 2 Fujitsu LifeBook N3510 RAM Replacement: step 7, image 2 of 2
    • Carefully pull RAM module from computer.
Neil Daniels
1,411 Reputation
11 Guides authored
Cal Poly, Team 5-18, Amido Winter 2011 Member of Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Members
22 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,081
