Fujitsu LifeBook N3510 Display Replacement
  1. Fujitsu LifeBook N3510 Display Replacement, Battery: step 1, image 1 of 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Display Replacement: step 2, image 1 of 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: step 3, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: step 3, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: step 3, image 3 of 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Display Replacement: step 4, image 1 of 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Display Replacement: step 5, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement: step 5, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement: step 5, image 3 of 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Display Replacement: step 6, image 1 of 2 Fujitsu LifeBook N3510 Display Replacement: step 6, image 2 of 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Display Replacement: step 7, image 1 of 2 Fujitsu LifeBook N3510 Display Replacement: step 7, image 2 of 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Display Replacement, Keyboard: step 8, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement, Keyboard: step 8, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement, Keyboard: step 8, image 3 of 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Display Replacement: step 9, image 1 of 2 Fujitsu LifeBook N3510 Display Replacement: step 9, image 2 of 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Display Replacement: step 10, image 1 of 2 Fujitsu LifeBook N3510 Display Replacement: step 10, image 2 of 2
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Display Replacement, Metal Motherboard Cover: step 11, image 1 of 1
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Display Replacement: step 12, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement: step 12, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement: step 12, image 3 of 3
    • Lift the cover with fingers and remove.
  13. Fujitsu LifeBook N3510 Display Replacement, Display: step 13, image 1 of 1
    • Remove labeled screws.
  14. Fujitsu LifeBook N3510 Display Replacement: step 14, image 1 of 1
    • Remove the screws from the bottom of the hinge as shown in the image.
  15. Fujitsu LifeBook N3510 Display Replacement: step 15, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement: step 15, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement: step 15, image 3 of 3
    • Use a spudger to detach and remove cables from the motherboard.
  16. Fujitsu LifeBook N3510 Display Replacement: step 16, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement: step 16, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement: step 16, image 3 of 3
    • Unplug highlighted cables from the wireless module.
  17. Fujitsu LifeBook N3510 Display Replacement: step 17, image 1 of 3 Fujitsu LifeBook N3510 Display Replacement: step 17, image 2 of 3 Fujitsu LifeBook N3510 Display Replacement: step 17, image 3 of 3
    • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
Neil Daniels
1,411 Reputation
11 Guides authored
Cal Poly, Team 5-18, Amido Winter 2011 Member of Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Members
22 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 11
All Time: 4,448
