Installing Fujifilm Finepix F10 6.3 MP LCD
  1. Installing Fujifilm Finepix F10 6.3 MP LCD, Back Cover: step 1, image 1 of 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Installing Fujifilm Finepix F10 6.3 MP LCD: step 2, image 1 of 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Installing Fujifilm Finepix F10 6.3 MP LCD: step 3, image 1 of 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Installing Fujifilm Finepix F10 6.3 MP LCD: step 4, image 1 of 3 Installing Fujifilm Finepix F10 6.3 MP LCD: step 4, image 2 of 3 Installing Fujifilm Finepix F10 6.3 MP LCD: step 4, image 3 of 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Installing Fujifilm Finepix F10 6.3 MP LCD, LCD: step 5, image 1 of 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Installing Fujifilm Finepix F10 6.3 MP LCD: step 6, image 1 of 1
    • Slide casing out using the spudger.
  7. Installing Fujifilm Finepix F10 6.3 MP LCD: step 7, image 1 of 2 Installing Fujifilm Finepix F10 6.3 MP LCD: step 7, image 2 of 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Sarah Looper
100 Reputation
7 Guides authored
Clemson, Team 13-4, Benson Spring 2013 Member of Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 984
