Fujifilm FinePix Z1 Lens Barrier Replacement
  1. Fujifilm FinePix Z1 Lens Barrier Replacement, Lens Barrier: step 1, image 1 of 2 Fujifilm FinePix Z1 Lens Barrier Replacement, Lens Barrier: step 1, image 2 of 2
    • Find the front face of the camera and test to see of the Lens Barrier will slide.
    • Make sure items are not trapped or stuck between the Lens Barrier and the camera lens.
    • Check to see if the camera power turns on by sliding the barrier. If not check to see if the lens barrier is on the correct track.
  2. Fujifilm FinePix Z1 Lens Barrier Replacement: step 2, image 1 of 3 Fujifilm FinePix Z1 Lens Barrier Replacement: step 2, image 2 of 3 Fujifilm FinePix Z1 Lens Barrier Replacement: step 2, image 3 of 3
    • Open the camera by removing the 5x4.0 mm external screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 Lens Barrier Replacement: step 3, image 1 of 2 Fujifilm FinePix Z1 Lens Barrier Replacement: step 3, image 2 of 2
    • Gently pull the top and bottom apart.
    • Make sure the circular spring on the back of the door is intact by manoeuvring the lens barrier and finding the sticking point.
  4. Fujifilm FinePix Z1 Lens Barrier Replacement: step 4, image 1 of 2 Fujifilm FinePix Z1 Lens Barrier Replacement: step 4, image 2 of 2
    • Find the thin, flat orange cable connector that operates the lens barrier and connects it to the main circuit board.
    • Check to make sure the cable is not stuck or broken.
  5. Fujifilm FinePix Z1 Lens Barrier Replacement: step 5, image 1 of 2 Fujifilm FinePix Z1 Lens Barrier Replacement: step 5, image 2 of 2
    • Replace lens cable connector if it is damaged.
    • This last step will require you to solder some of the cable connectors. Click here to learn how to complete this step.
Carra
533 Reputation
4 Guides authored
Baylor, Team S2-G4, Johnson Spring 2018 Member of Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 258
