Frigidaire Stove Bake Element Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Unplug the stove before touching any internal parts.
      • Let the oven cool completely if it was used recently.
      • Move the stove only as much as needed to reach the rear wiring later in the repair.
      Ask FixBot
      • Open the oven door and find the locking tab on each hinge.
      • Pull both hinge tabs down until they stop.
      • Close the door slowly until it rests against the lowered hinge tabs.
      • Support the door with both hands, lift it straight up, and pull it away from the stove.
      • Set the door on a stable surface where it cannot fall.
      Ask FixBot
      • Slide each oven rack toward you.
      • Lift the front of the rack when it reaches the stop.
      • Pull each rack out of the oven cavity.
      • Set the racks aside.
      Ask FixBot
      • Locate the bottom panel that covers the bake element.
      • Remove the two Phillips screws, one on each side of the panel.
      • Each side uses a screw and a washer, so keep each washer with its screw.
      • The original panel screws may have flatter heads than common replacements.
      • If the panel screws are rusted or damaged, replace them with 8-32 screws.
      Ask FixBot
      • Insert a flathead screwdriver into one of the screw holes.
      • Lift the back edge of the bottom panel with the screwdriver.
      • Grab both sides of the panel and raise the rear edge.
      • Pull the front edge out from under the front lip.
      • Remove the bottom panel from the oven.
      Ask FixBot
      • Locate the four screws securing the bake element.
      • These four bake-element screws use 1/4 inch heads.
      • Remove the two front screws with a 1/4 inch nut driver.
      • Remove the two rear screws with a 1/4 inch nut driver.
      • Keep all four screws together for reassembly.
      Ask FixBot
      • Move to the back of the stove where the bake-element terminals are accessible.
      • Disconnect the orange wire from one bake-element terminal.
      • Disconnect the yellow wire from the other terminal.
      • Pull on the connectors, not the wire itself, so you do not damage the harness.
      • Disconnecting the wires from the rear is usually easier than pulling them through the front holes.
      Ask FixBot
      • Return to the oven cavity.
      • Pull the bake element straight out of the oven.
      • Remove the old bake element from the stove.
      Ask FixBot
      • Set the replacement bake element into the oven cavity.
      • Guide the rear terminals through the holes at the back of the oven.
      • Reconnect the yellow and orange wires to the bake-element terminals from the rear of the stove.
      • Make sure both connectors are fully seated before you cover the element again.
      Ask FixBot
      • Reinstall the four bake-element screws with a 1/4 inch nut driver.
      • Install two screws at the front and two at the rear.
      • Make sure the element sits flat in its original position under the oven floor.
      Ask FixBot
      • Slide the front edge of the bottom panel under the front lip of the oven.
      • Lower the back edge into place.
      • Install a washer and Phillips screw on each side of the bottom panel.
      • Tighten the two panel screws with a Phillips screwdriver.
      • Use 8-32 screws if the originals were replaced.
      Ask FixBot
      • Slide the oven racks back onto their supports.
      • Support the oven door with both hands while you align the hinges.
      • Insert the door hinges into their slots.
      • Open the door fully and push both hinge tabs back up.
      • Close the door and confirm that it moves normally.
      Ask FixBot
      • Reinstall any rear access panel you removed during the repair.
      • Plug the stove back in.
      • Set the oven to Bake and confirm that the lower element begins heating.
      • Keep your hands away from the heating elements during the test.
      • If the oven stays cold, unplug the stove and verify that the yellow and orange wires are fully connected before continuing diagnosis.
      Ask FixBot
Use the bake element troubleshooting resource if the oven still doesn't heat, or browse the Frigidaire and Kenmore stove repair playlist for related repairs. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 92
All Time: 161
