Frigidaire Gallery Water Filter Replacement
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: step 1, image 1 of 1
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: step 2, image 1 of 2 Frigidaire Gallery Water Filter Replacement: step 2, image 2 of 2
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: step 3, image 1 of 3 Frigidaire Gallery Water Filter Replacement: step 3, image 2 of 3 Frigidaire Gallery Water Filter Replacement: step 3, image 3 of 3
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: step 4, image 1 of 1
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Finish Line
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 57
Past 30 Days: 183
All Time: 8,774
