Shop the Holiday Gift Guide
Framework Laptop 16 Wi-Fi Module Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
106
All Time:
423
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the Wi-Fi module in your Framework Laptop 16.
The Wi-Fi module is a modular card that enables Wi-Fi and Bluetooth functions. While the Framework Laptop 16 works with M.2 2230 Wi-Fi cards, Framework recommends replacing it with the same model of card that the system originally came with.
The Wi-Fi module has delicate antenna connectors. Be sure to follow the instructions carefully to avoid damaging them.
    1. Framework Laptop 16 Wi-Fi Module Replacement, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Spacers: step 2, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Spacers: step 2, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Spacers: step 2, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    2. Framework Laptop 16 Wi-Fi Module Replacement: step 3, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement: step 3, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement: step 3, image 3 of 3
      • Repeat the same procedure for the other touchpad spacer.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Module: step 4, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Module: step 4, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Module: step 4, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Remove the keyboard: step 5, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the keyboard: step 5, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the keyboard: step 5, image 3 of 3
      • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
      • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
      • Remove the keyboard.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Input Modules: step 6, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Input Modules: step 6, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Input Modules: step 6, image 3 of 3
      • Your Input Module(s) might be different, but the procedure to remove them is the same.
      • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
      • Remove the Input Module.
      • Repeat for any remaining Input Modules.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Mid Plate cable: step 7, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Mid Plate cable: step 7, image 2 of 2
      • Grip the black pull tab on the Mid Plate cable press connector.
      • Lift up to disconnect the Mid Plate cable.
      Ask FixBot
    2. Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Mid Plate screws: step 8, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Mid Plate screws: step 8, image 2 of 2
      • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
      • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
      Ask FixBot
    3. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Mid Plate: step 9, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Mid Plate: step 9, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Mid Plate: step 9, image 3 of 3
      • Use your fingers to lift the Mid Plate off the laptop and remove it.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Wi-Fi module screw: step 10, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Wi-Fi module screw: step 10, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing Wi-Fi module.
      • The module might pop up at a shallow angle when you loosen the screw.
      Ask FixBot
    2. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi module cover: step 11, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi module cover: step 11, image 2 of 2
      • Slide the clear plastic cover straight off the module and remove it.
      Ask FixBot
    3. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi Module: step 12, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi Module: step 12, image 2 of 2
      • Grip the end of the Wi-Fi Module with the screw hole and slide it out of its socket.
      • Remove the Wi-Fi Module.
      Ask FixBot
    4. Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Wi-Fi module: step 13, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Wi-Fi module: step 13, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Wi-Fi module: step 13, image 3 of 3
      • While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver under one of the coaxial connectors, where the cable meets the metal head.
      • Lift the screwdriver straight up to disconnect the coaxial cable.
      • Repeat for the other coaxial cable.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Disassembly complete: step 14, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Install the Wi-Fi module: step 15, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Install the Wi-Fi module: step 15, image 2 of 2
      • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    2. Framework Laptop 16 Wi-Fi Module Replacement: step 16, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement: step 16, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement: step 16, image 3 of 3
      • Hold the Wi-Fi module down with your finger.
      • Position the white antenna cable connector over the left Wi-Fi module's coaxial socket.
      • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the black antenna cable.
      Ask FixBot
    3. Framework Laptop 16 Wi-Fi Module Replacement: step 17, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement: step 17, image 2 of 2
      • Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
      Ask FixBot
    4. Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Wi-Fi module screw: step 18, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Wi-Fi module screw: step 18, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Place the Mid Plate: step 19, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Place the Mid Plate: step 19, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Place the Mid Plate: step 19, image 3 of 3
      • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
      Ask FixBot
    2. Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Mid Plate screws: step 20, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Mid Plate screws: step 20, image 2 of 2
      • Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
      Ask FixBot
    3. Framework Laptop 16 Wi-Fi Module Replacement, Connect the Mid Plate cable: step 21, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Connect the Mid Plate cable: step 21, image 2 of 2
      • Align the Mid Plate cable press connector over its socket and press down to connect it.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Install the Input Modules: step 22, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Input Modules: step 22, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Input Modules: step 22, image 3 of 3
      • Align the top edge of the Input Module with the top edge of the laptop.
      • Lay the Input Module on the laptop and let the magnets pull the keyboard into place
      • Make sure the Input Module is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Install the keyboard: step 23, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Install the keyboard: step 23, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Install the keyboard: step 23, image 3 of 3
      • Align the top edge of the keyboard with the top edge of the laptop.
      • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
      • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Module: step 24, image 1 of 2 Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Module: step 24, image 2 of 2
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Spacers: step 25, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Spacers: step 25, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Spacers: step 25, image 3 of 3
      • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
      • Slide the Touchpad Spacer towards the top of the laptop to secure it.
      • Repeat the same procedure for the other Touchpad Spacer.
      Ask FixBot
    2. Framework Laptop 16 Wi-Fi Module Replacement, Lock the Input Modules: step 26, image 1 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Lock the Input Modules: step 26, image 2 of 3 Framework Laptop 16 Wi-Fi Module Replacement, Lock the Input Modules: step 26, image 3 of 3
      • Push the Input Module latches back into place to lock them.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
252,429 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 106
All Time: 423
