Grip the Hall Effect cable connector by its black pull tab and slide it straight out of its socket.
While supporting the Top Cover with one hand, use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the webcam ZIF connector.
Use your fingers to peel off the flat portion of the webcam cable from its adhesive near the top edge of the Top Cover.
At this point, the webcam cable should be free and you can remove it.
