Framework Laptop 16 Webcam Cable Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Webcam Cable Installation, Connect the Hall Effect sensor: step 1, image 1 of 2 Framework Laptop 16 Webcam Cable Installation, Connect the Hall Effect sensor: step 1, image 2 of 2
      • Grip the Hall Effect cable connector by its black pull tab and slide it straight into its socket.
      Ask FixBot
    2. Framework Laptop 16 Webcam Cable Installation, Connect the webcam: step 2, image 1 of 2 Framework Laptop 16 Webcam Cable Installation, Connect the webcam: step 2, image 2 of 2
      • Use your fingers to slide the webcam cable straight into its socket.
      Ask FixBot
    3. Framework Laptop 16 Webcam Cable Installation: step 3, image 1 of 2 Framework Laptop 16 Webcam Cable Installation: step 3, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the webcam ZIF connector.
      Ask FixBot
    4. Framework Laptop 16 Webcam Cable Installation, Re‑adhere the webcam cable: step 4, image 1 of 3 Framework Laptop 16 Webcam Cable Installation, Re‑adhere the webcam cable: step 4, image 2 of 3 Framework Laptop 16 Webcam Cable Installation, Re‑adhere the webcam cable: step 4, image 3 of 3
      • Align the thick portion of the webcam cable with the adhesive near the bottom edge of the Top Cover.
      • Press the cable to the Top Cover to re‑adhere it.
      • Press the bend in the webcam cable to the Top Cover to re‑adhere it, making sure it sits against its vertical protrusion.
      Ask FixBot
    5. Framework Laptop 16 Webcam Cable Installation: step 5, image 1 of 3 Framework Laptop 16 Webcam Cable Installation: step 5, image 2 of 3 Framework Laptop 16 Webcam Cable Installation: step 5, image 3 of 3
      • Grip the thin portion of the webcam cable and pull it downward so it sits flat against the Top Cover.
      • Press the cable to the adhesive near the center of the Top Cover to re‑adhere it.
      Ask FixBot
    6. Framework Laptop 16 Webcam Cable Installation: step 6, image 1 of 3 Framework Laptop 16 Webcam Cable Installation: step 6, image 2 of 3 Framework Laptop 16 Webcam Cable Installation: step 6, image 3 of 3
      • Press the cable to the adhesive near the top edge of the Top Cover to re‑adhere it.
      • Slide your finger down the cable to smooth out any creases.
      Ask FixBot
Alex Diaz-Kokaisl
249,973 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 68
