Framework Laptop 16 Touchpad Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
60
All Time:
263
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the Touchpad Module in your Framework Laptop 16.
    1. Framework Laptop 16 Touchpad Module Replacement, Remove the Touchpad Module: step 1, image 1 of 3 Framework Laptop 16 Touchpad Module Replacement, Remove the Touchpad Module: step 1, image 2 of 3 Framework Laptop 16 Touchpad Module Replacement, Remove the Touchpad Module: step 1, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16 Touchpad Module Replacement, Install the Touchpad Module: step 2, image 1 of 2 Framework Laptop 16 Touchpad Module Replacement, Install the Touchpad Module: step 2, image 2 of 2
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    2. Framework Laptop 16 Touchpad Module Replacement, Lock the Input Modules: step 3, image 1 of 3 Framework Laptop 16 Touchpad Module Replacement, Lock the Input Modules: step 3, image 2 of 3 Framework Laptop 16 Touchpad Module Replacement, Lock the Input Modules: step 3, image 3 of 3
      • Push the Input Module latches back into place to lock them.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
251,591 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 60
All Time: 263
