Framework Laptop 16 Hinges Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Hinges Installation, Place the hinges: step 1, image 1 of 3 Framework Laptop 16 Hinges Installation, Place the hinges: step 1, image 2 of 3 Framework Laptop 16 Hinges Installation, Place the hinges: step 1, image 3 of 3
      • Place the hinges in their slots on the Bottom Cover, making sure they sit in their alignment pegs.
      • The hinges are labeled R for right and L for left.
      Ask FixBot
    2. Framework Laptop 16 Hinges Installation, Install the hinge screws: step 2, image 1 of 2 Framework Laptop 16 Hinges Installation, Install the hinge screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to install the four 3.9 mm‑long screws on each hinge connected to the Top Cover (8 total).
      Ask FixBot
    3. Framework Laptop 16 Hinges Installation, Place the Bottom Cover: step 3, image 1 of 2 Framework Laptop 16 Hinges Installation, Place the Bottom Cover: step 3, image 2 of 2
      • Place the Bottom Cover over the Top Cover, making sure the hinges are slotted into their alignment pegs.
      Ask FixBot
    4. Framework Laptop 16 Hinges Installation, Install the hinge screws: step 4, image 1 of 3 Framework Laptop 16 Hinges Installation, Install the hinge screws: step 4, image 2 of 3 Framework Laptop 16 Hinges Installation, Install the hinge screws: step 4, image 3 of 3
      • While supporting the Bottom Cover with one hand, use your Framework Screwdriver to install the five 2.4 mm‑long screws on each hinge connected to the Top Cover (10 total).
      Ask FixBot
    5. Framework Laptop 16 Hinges Installation, Reposition the laptop: step 5, image 1 of 2 Framework Laptop 16 Hinges Installation, Reposition the laptop: step 5, image 2 of 2
      • Tilt the laptop forwards and let it rest on its Bottom Cover.
      Ask FixBot
Alex Diaz-Kokaisl
249,976 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 70
