Shop the Holiday Gift Guide
Framework Laptop 16 Graphics Module Thermal Pad Installation
View statistics:
Past 24 Hours:
6
Past 7 Days:
13
Past 30 Days:
19
All Time:
99
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Graphics Module Thermal Pad Installation, Remove the old thermal compound: step 1, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Remove the old thermal compound: step 1, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Remove the old thermal compound: step 1, image 3 of 3
      • Your Graphics Module will have either a thermal pad or thermal paste. Follow the procedure normally to remove either compound.
      • Use a few drops of high concentration (>90%) isopropyl alcohol and a lint-free cloth to wipe away the thermal compound residue.
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Thermal Pad Installation: step 2, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation: step 2, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation: step 2, image 3 of 3
      • Repeat the previous step for the thermal compound residue on the bottom of the heatsink.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Thermal Pad Installation, Apply the new thermal pad: step 3, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Apply the new thermal pad: step 3, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Apply the new thermal pad: step 3, image 3 of 3
      • Peel off the clear liner from the thermal pad to expose one side of it.
      • Place the exposed side of the thermal pad over the CPU.
      • If you have trouble handling your thermal pad, you can store it in your fridge for a few minutes to make it more rigid.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Thermal Pad Installation: step 4, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation: step 4, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation: step 4, image 3 of 3
      • Use your finger to lightly press the thermal pad to the GPU and bond it.
      • Remove the green liner from the thermal pad to expose its top side.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the CPU Heatsink: step 5, image 1 of 2 Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the CPU Heatsink: step 5, image 2 of 2
      • Align your heatsink over the CPU and place it straight down onto the Mainboard.
      • The thermal pad needs to go through a few thermal cycles before it gets to full performance.
      Ask FixBot
    6. Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the Graphics Module heatsink screws: step 6, image 1 of 2 Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the Graphics Module heatsink screws: step 6, image 2 of 2
      • The screw configuration will look different depending on your Graphics Module, but the procedure is the same.
      • Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the Graphics Module Heatsink:
      • Tighten the captive screws directly over the GPU in order from 4–1.
      • Tighten the captive screw at the bottom left corner of the heatsink.
      Ask FixBot
    7. Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the right fan: step 7, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the right fan: step 7, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the right fan: step 7, image 3 of 3
      • Place the right fan onto the Expansion Bay Shell, making sure to thread the cable through its slot.
      Ask FixBot
    8. Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the right fan screws: step 8, image 1 of 2 Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the right fan screws: step 8, image 2 of 2
      • Use a T5 Torx screwdriver to tighten the four captive screws securing the right fan.
      Ask FixBot
    9. Framework Laptop 16 Graphics Module Thermal Pad Installation, Connect the right fan: step 9, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Connect the right fan: step 9, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Connect the right fan: step 9, image 3 of 3
      • Use your fingers to grip the brown pull tab and slide the right fan cable straight into its socket.
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the fan ZIF connector.
      Ask FixBot
    10. Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the left fan: step 10, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the left fan: step 10, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the left fan: step 10, image 3 of 3
      • Place the left fan onto the Expansion Bay Shell, making sure to thread the cable through its slot.
      Ask FixBot
    11. Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the left fan screws: step 11, image 1 of 2 Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the left fan screws: step 11, image 2 of 2
      • Use a T5 Torx screwdriver to tighten the four captive screws securing the left fan.
      Ask FixBot
    12. Framework Laptop 16 Graphics Module Thermal Pad Installation, Connect the left fan: step 12, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Connect the left fan: step 12, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Connect the left fan: step 12, image 3 of 3
      • Use your fingers to grip the brown pull tab and slide the left fan cable straight into its socket.
      Ask FixBot
    13. Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the Graphics Module cover: step 13, image 1 of 2 Framework Laptop 16 Graphics Module Thermal Pad Installation, Place the Graphics Module cover: step 13, image 2 of 2
      • Place the cover over its slot on the Graphics Module.
      Ask FixBot
    14. Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the Graphics Module cover screws: step 14, image 1 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the Graphics Module cover screws: step 14, image 2 of 3 Framework Laptop 16 Graphics Module Thermal Pad Installation, Install the Graphics Module cover screws: step 14, image 3 of 3
      • Use your Framework Screwdriver to install the four 3.6 mm‑long T5 Torx screws securing the Graphics Module cover:
      • Two screws on the flat surface of the module, next to the fans.
      • Two screws on the thin edge of the module, near the ends. You'll need to flip the module on its back edge to access them.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 19
All Time: 99
