Shop the Holiday Gift Guide
Framework Laptop 16 Graphics Module Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
8
All Time:
106
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to remove the expansion bay in your Framework 16" laptop.
Tools
    1. Framework Laptop 16 Graphics Module Removal, Lift the interposer door: step 1, image 1 of 2 Framework Laptop 16 Graphics Module Removal, Lift the interposer door: step 1, image 2 of 2
      • Lift the interposer door by its black pull tab and let it rest upright.
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Removal, Loosen the interposer screws: step 2, image 1 of 1
      • Use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Removal, Remove the interposer: step 3, image 1 of 2 Framework Laptop 16 Graphics Module Removal, Remove the interposer: step 3, image 2 of 2
      • Lift the interposer by its pull tab and remove it.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Removal, Loosen the Graphics Module screws: step 4, image 1 of 2 Framework Laptop 16 Graphics Module Removal, Loosen the Graphics Module screws: step 4, image 2 of 2
      • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the Graphics Module.
      • Close the interposer door before continuing.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Removal, Remove the Graphics Module: step 5, image 1 of 3 Framework Laptop 16 Graphics Module Removal, Remove the Graphics Module: step 5, image 2 of 3 Framework Laptop 16 Graphics Module Removal, Remove the Graphics Module: step 5, image 3 of 3
      • Close your laptop and flip it over.
      • Slide the Graphics Module out of the laptop and remove it.
      • The module should slide out easily. If you feel any resistance, check that the screws holding it in place are fully loosened.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 106
