Shop the Holiday Gift Guide
Framework Laptop 16 Graphics Module Installation
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
4
All Time:
95
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Framework Laptop 16 Graphics Module Installation, Insert the Graphics Module: step 1, image 1 of 2 Framework Laptop 16 Graphics Module Installation, Insert the Graphics Module: step 1, image 2 of 2
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Installation: step 2, image 1 of 2 Framework Laptop 16 Graphics Module Installation: step 2, image 2 of 2
      • When installing the module, keep it level to the laptop so it doesn't buckle on the rails.
      • There should be no gaps between the laptop and the module when it's installed correctly.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Installation: step 3, image 1 of 3 Framework Laptop 16 Graphics Module Installation: step 3, image 2 of 3 Framework Laptop 16 Graphics Module Installation: step 3, image 3 of 3
      • While keeping the module level with the laptop, slide it into its slot.
      • The module should slide in easily. If you feel any resistance, pull the module out and realign it.
      • You should hear an audible "click" when the module's clips snap into place.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Installation, Lift the interposer door: step 4, image 1 of 2 Framework Laptop 16 Graphics Module Installation, Lift the interposer door: step 4, image 2 of 2
      • Flip over the laptop and open it.
      • Lift the interposer door by its black pull tab and let it rest upright.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Installation, Tighten the Graphics Module screws: step 5, image 1 of 2 Framework Laptop 16 Graphics Module Installation, Tighten the Graphics Module screws: step 5, image 2 of 2
      • Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Graphics Module.
      Ask FixBot
    6. Framework Laptop 16 Graphics Module Installation, Place the interposer: step 6, image 1 of 2 Framework Laptop 16 Graphics Module Installation, Place the interposer: step 6, image 2 of 2
      • Place the interposer over its spot between the Mainboard and the Graphics Module.
      Ask FixBot
    7. Framework Laptop 16 Graphics Module Installation, Tighten the interposer screws: step 7, image 1 of 2 Framework Laptop 16 Graphics Module Installation, Tighten the interposer screws: step 7, image 2 of 2
      • Use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer.
      • Close the interposer door.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
252,773 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 95
