Framework Laptop 16 Fastener Guide
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
58
All Time:
318
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Did you lose a screw in your Framework Laptop 16? Fear not! Follow this guide to replace your missing screws with the Framework Laptop 16 Fastener Kit.
The Fastener Kit only replaces the non-captive screws in your laptop.
Use the links below to jump to the part and find which screw to use:
    1. Framework Laptop 16 Fastener Guide, Fasteners information: step 1, image 1 of 2 Framework Laptop 16 Fastener Guide, Fasteners information: step 1, image 2 of 2
      • The Fastener Kit contains the following:
      • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
      • Silver screws labeled "M1.2 1.0mm fastener with a 3.5mm diameter 0.25mm thick PH0 head"
      • Grey screws labeled "M1.4 1.8mm fastener with a 4.0mm diameter 0.4mm thick PH0 head"
      • Gold screws labeled "M1.4 1.4mm fastener with a 4.5mm diameter 0.6mm thick T5 head"
      • Gold screws labeled "M2 3.0mm fastener with a 4.5mm diameter 0.7mm thick T5 head"
      • Black screws labeled "M2.5 3.5mm fastener with a 4.5mm diameter 0.5mm thick T5 head"
      • Your Framework Laptop comes with a spare screw of each size, attached to the chassis under the ventilation plate. You can use the Fastener Kit to replenish any screws you used there.
      Ask FixBot
    2. Framework Laptop 16 Fastener Guide: step 2, image 1 of 1
      • The Fastener Kit also comes with two additional sets of screws that aren't included with the spares:
      • Grey screws labeled "M2 2.6mm fastener with a 5.5mm diameter 0.8mm thick T5 head"
      • Grey screws labeled "M2 2.0mm fastener with a 4.5mm diameter 0.5mm thick T5 head"
      Ask FixBot
    3. Framework Laptop 16 Fastener Guide, Webcam and Mainboard screws: step 3, image 1 of 3 Framework Laptop 16 Fastener Guide, Webcam and Mainboard screws: step 3, image 2 of 3 Framework Laptop 16 Fastener Guide, Webcam and Mainboard screws: step 3, image 3 of 3
      • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Webcam and Mainboard.
      Ask FixBot
    4. Framework Laptop 16 Fastener Guide, Input Connector Board and Input Module screws: step 4, image 1 of 3 Framework Laptop 16 Fastener Guide, Input Connector Board and Input Module screws: step 4, image 2 of 3 Framework Laptop 16 Fastener Guide, Input Connector Board and Input Module screws: step 4, image 3 of 3
      • Use the silver screws labeled "M1.2 1.0mm fastener with a 3.5mm diameter 0.25mm thick PH0 head" to secure the Input Connector Board and Input Module.
      Ask FixBot
    5. Framework Laptop 16 Fastener Guide, Fingerprint Reader and Touchpad screws: step 5, image 1 of 3 Framework Laptop 16 Fastener Guide, Fingerprint Reader and Touchpad screws: step 5, image 2 of 3 Framework Laptop 16 Fastener Guide, Fingerprint Reader and Touchpad screws: step 5, image 3 of 3
      • Use the grey screws labeled "M1.4 1.8mm fastener with a 4.0mm diameter 0.4mm thick PH0 head" to secure the Fingerprint Reader and the bottom of the Touchpad.
      Ask FixBot
    6. Framework Laptop 16 Fastener Guide, Storage screws: step 6, image 1 of 3 Framework Laptop 16 Fastener Guide, Storage screws: step 6, image 2 of 3 Framework Laptop 16 Fastener Guide, Storage screws: step 6, image 3 of 3
      • Use the gold screws labeled "M1.4 1.4mm fastener with a 4.5mm diameter 0.6mm thick T5 head" to secure the Primary and Secondary Storage.
      Ask FixBot
    7. Framework Laptop 16 Fastener Guide, Expansion Bay Shell screws: step 7, image 1 of 3 Framework Laptop 16 Fastener Guide, Expansion Bay Shell screws: step 7, image 2 of 3 Framework Laptop 16 Fastener Guide, Expansion Bay Shell screws: step 7, image 3 of 3
      • Use the gold screws labeled "M2 3.0mm fastener with a 4.5mm diameter 0.7mm thick T5 head" to secure the Expansion Bay Shell components.
      Ask FixBot
    8. Framework Laptop 16 Fastener Guide, Graphics Module screws: step 8, image 1 of 3 Framework Laptop 16 Fastener Guide, Graphics Module screws: step 8, image 2 of 3 Framework Laptop 16 Fastener Guide, Graphics Module screws: step 8, image 3 of 3
      • Use the gold screws labeled "M2 3.0mm fastener with a 4.5mm diameter 0.7mm thick T5 head" to secure the Graphics Module cover.
      Ask FixBot
    9. Framework Laptop 16 Fastener Guide, Hinge screws: step 9, image 1 of 3 Framework Laptop 16 Fastener Guide, Hinge screws: step 9, image 2 of 3 Framework Laptop 16 Fastener Guide, Hinge screws: step 9, image 3 of 3
      • Use the black screws labeled "M2.5 2.0mm fastener with a 4.5mm diameter 0.5mm thick T5 head" to secure the hinges to the bottom cover.
      Ask FixBot
    10. Framework Laptop 16 Fastener Guide, Bottom Cover screws: step 10, image 1 of 2 Framework Laptop 16 Fastener Guide, Bottom Cover screws: step 10, image 2 of 2
      • Use the grey screws labeled "M2 2.6mm fastener with a 5.5mm diameter 0.8mm thick T5 head" to secure the Bottom Cover screws.
      Ask FixBot
    11. Framework Laptop 16 Fastener Guide, Display screws: step 11, image 1 of 2 Framework Laptop 16 Fastener Guide, Display screws: step 11, image 2 of 2
      • Use the grey screws labeled "M2 2.0mm fastener with a 4.5mm diameter 0.5mm thick T5 head" to secure the display.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
251,591 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 58
All Time: 318
