Framework Laptop 16 Expansion Card Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Expansion Card Installation, Reposition the laptop: step 1, image 1 of 2 Framework Laptop 16 Expansion Card Installation, Reposition the laptop: step 1, image 2 of 2
      • Close the laptop and flip it over.
      Ask FixBot
    2. Framework Laptop 16 Expansion Card Installation, Install the Expansion Cards: step 2, image 1 of 3 Framework Laptop 16 Expansion Card Installation, Install the Expansion Cards: step 2, image 2 of 3 Framework Laptop 16 Expansion Card Installation, Install the Expansion Cards: step 2, image 3 of 3
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latch to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      • Repeat for all remaining Expansion Cards.
      Ask FixBot
    3. Framework Laptop 16 Expansion Card Installation: step 3, image 1 of 2 Framework Laptop 16 Expansion Card Installation: step 3, image 2 of 2
      • Use your finger to flip both latches and lock the row of Expansion Cards above them.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
250,028 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 82
