Framework Laptop 16 Expansion Bay Shell Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Expansion Bay Shell Installation, Insert the Expansion Bay Shell: step 1, image 1 of 2 Framework Laptop 16 Expansion Bay Shell Installation, Insert the Expansion Bay Shell: step 1, image 2 of 2
      Ask FixBot
    2. Framework Laptop 16 Expansion Bay Shell Installation: step 2, image 1 of 2 Framework Laptop 16 Expansion Bay Shell Installation: step 2, image 2 of 2
      • When installing the shell, keep it level to the laptop so it doesn't buckle on the rails.
      • There should be no gaps between the laptop and the shell when it's installed correctly.
      Ask FixBot
    3. Framework Laptop 16 Expansion Bay Shell Installation: step 3, image 1 of 3 Framework Laptop 16 Expansion Bay Shell Installation: step 3, image 2 of 3 Framework Laptop 16 Expansion Bay Shell Installation: step 3, image 3 of 3
      • While keeping the shell level with the laptop, slide it into its slot.
      • The shell should slide in easily. If you feel any resistance, pull the module out and realign it.
      • You should hear an audible "click" when the shell's clips snap into place.
      Ask FixBot
    4. Framework Laptop 16 Expansion Bay Shell Installation, Lift the interposer door: step 4, image 1 of 2 Framework Laptop 16 Expansion Bay Shell Installation, Lift the interposer door: step 4, image 2 of 2
      • Flip over the laptop and open it.
      • Lift the interposer door by its black pull tab and let it rest upright.
      Ask FixBot
    5. Framework Laptop 16 Expansion Bay Shell Installation, Tighten the Expansion Bay Shell screws: step 5, image 1 of 2 Framework Laptop 16 Expansion Bay Shell Installation, Tighten the Expansion Bay Shell screws: step 5, image 2 of 2
      • Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Shell.
      Ask FixBot
    6. Framework Laptop 16 Expansion Bay Shell Installation, Place the interposer: step 6, image 1 of 2 Framework Laptop 16 Expansion Bay Shell Installation, Place the interposer: step 6, image 2 of 2
      • Place the interposer over its spot between the Mainboard and the Expansion Bay.
      Ask FixBot
    7. Framework Laptop 16 Expansion Bay Shell Installation, Tighten the interposer screws: step 7, image 1 of 2 Framework Laptop 16 Expansion Bay Shell Installation, Tighten the interposer screws: step 7, image 2 of 2
      • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the interposer.
      • Close the interposer door.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
250,021 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 96
