Framework Laptop 16 Display Cable Removal (All)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Display Cable Removal (All), Disconnect the display cables: step 1, image 1 of 3 Framework Laptop 16 Display Cable Removal (All), Disconnect the display cables: step 1, image 2 of 3 Framework Laptop 16 Display Cable Removal (All), Disconnect the display cables: step 1, image 3 of 3
      • Grip the eDP cable connector to the right of the Wi-Fi module slot by its pull tab and lift up to disconnect it.
      • Repeat for the webcam cable connector next to it.
      Ask FixBot
    2. Framework Laptop 16 Display Cable Removal (All), Reroute the cables: step 2, image 1 of 3 Framework Laptop 16 Display Cable Removal (All), Reroute the cables: step 2, image 2 of 3 Framework Laptop 16 Display Cable Removal (All), Reroute the cables: step 2, image 3 of 3
      • Lift the eDP, webcam, and antenna cables out of their vertical slot in the Bottom Cover.
      Ask FixBot
    3. Framework Laptop 16 Display Cable Removal (All): step 3, image 1 of 3 Framework Laptop 16 Display Cable Removal (All): step 3, image 2 of 3 Framework Laptop 16 Display Cable Removal (All): step 3, image 3 of 3
      • Use your fingers to guide the eDP cable out of its clips along the top left edge of the Bottom Cover.
      Ask FixBot
    4. Framework Laptop 16 Display Cable Removal (All): step 4, image 1 of 3 Framework Laptop 16 Display Cable Removal (All): step 4, image 2 of 3 Framework Laptop 16 Display Cable Removal (All): step 4, image 3 of 3
      • Repeat the previous step for the black antenna cable.
      Ask FixBot
    5. Framework Laptop 16 Display Cable Removal (All): step 5, image 1 of 3 Framework Laptop 16 Display Cable Removal (All): step 5, image 2 of 3 Framework Laptop 16 Display Cable Removal (All): step 5, image 3 of 3
      • Use your fingers to guide the white antenna cable out of its clips along the top right edge of the Bottom Cover.
      Ask FixBot
    6. Framework Laptop 16 Display Cable Removal (All): step 6, image 1 of 3 Framework Laptop 16 Display Cable Removal (All): step 6, image 2 of 3 Framework Laptop 16 Display Cable Removal (All): step 6, image 3 of 3
      • Repeat the previous step for the webcam cable.
      Ask FixBot
Alex Diaz-Kokaisl
250,021 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 13
All Time: 102
