Framework Laptop 16 Display Cable Installation (All)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Display Cable Installation (All), Reroute the cables: step 1, image 1 of 3 Framework Laptop 16 Display Cable Installation (All), Reroute the cables: step 1, image 2 of 3 Framework Laptop 16 Display Cable Installation (All), Reroute the cables: step 1, image 3 of 3
      • Use the flat end of your Framework Screwdriver, or your fingers, to press the webcam cable into its clips at the top right edge of the Bottom Cover.
      Ask FixBot
    2. Framework Laptop 16 Display Cable Installation (All): step 2, image 1 of 3 Framework Laptop 16 Display Cable Installation (All): step 2, image 2 of 3 Framework Laptop 16 Display Cable Installation (All): step 2, image 3 of 3
      • Repeat the previous step for the white antenna cable.
      Ask FixBot
    3. Framework Laptop 16 Display Cable Installation (All): step 3, image 1 of 2 Framework Laptop 16 Display Cable Installation (All): step 3, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or your fingers, to press the black antenna cable into its clips at the top left edge of the Bottom Cover.
      Ask FixBot
    4. Framework Laptop 16 Display Cable Installation (All): step 4, image 1 of 2 Framework Laptop 16 Display Cable Installation (All): step 4, image 2 of 2
      • Repeat the previous step for the eDP cable.
      Ask FixBot
    5. Framework Laptop 16 Display Cable Installation (All): step 5, image 1 of 3 Framework Laptop 16 Display Cable Installation (All): step 5, image 2 of 3 Framework Laptop 16 Display Cable Installation (All): step 5, image 3 of 3
      • Press the eDP, webcam, and antenna cables into their vertical slot in the Bottom Cover.
      Ask FixBot
    6. Framework Laptop 16 Display Cable Installation (All), Connect the display cables: step 6, image 1 of 2 Framework Laptop 16 Display Cable Installation (All), Connect the display cables: step 6, image 2 of 2
      • Press the eDP and webcam cable connectors straight down into their sockets to connect them.
      Ask FixBot
Alex Diaz-Kokaisl
250,018 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 77
