Framework Laptop 16 CPU Heatsink Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 CPU Heatsink Installation, Clean the old liquid metal: step 1, image 1 of 3 Framework Laptop 16 CPU Heatsink Installation, Clean the old liquid metal: step 1, image 2 of 3 Framework Laptop 16 CPU Heatsink Installation, Clean the old liquid metal: step 1, image 3 of 3
      • If you're removing liquid metal, follow the next two steps. Otherwise skip here to remove the thermal pad.
      • Use the flat end of your Framework Screwdriver to scrape off the hardened sections of liquid metal on the CPU.
      • Use a few drops of high concentration (>90%) isopropyl alcohol and a lint-free cloth to wipe away the remaining residue.
      Ask FixBot
    2. Framework Laptop 16 CPU Heatsink Installation, Remove the plastic shield: step 2, image 1 of 3 Framework Laptop 16 CPU Heatsink Installation, Remove the plastic shield: step 2, image 2 of 3 Framework Laptop 16 CPU Heatsink Installation, Remove the plastic shield: step 2, image 3 of 3
      • Use your fingers to peel off the plastic shield surrounding the CPU.
      • If the foam pad on the CPU doesn't come off with the tape, use the flat end of your Framework Screwdriver to pry it off.
      • Skip the next step.
      Ask FixBot
    3. Framework Laptop 16 CPU Heatsink Installation, Remove the old thermal compound: step 3, image 1 of 2 Framework Laptop 16 CPU Heatsink Installation, Remove the old thermal compound: step 3, image 2 of 2
      • Use a few drops of high concentration (>90%) isopropyl alcohol and a lint-free cloth to wipe away the thermal pad residue.
      Ask FixBot
    4. Framework Laptop 16 CPU Heatsink Installation, Place the CPU Heatsink: step 4, image 1 of 3 Framework Laptop 16 CPU Heatsink Installation, Place the CPU Heatsink: step 4, image 2 of 3 Framework Laptop 16 CPU Heatsink Installation, Place the CPU Heatsink: step 4, image 3 of 3
      • Remove the liner from the bottom of your replacement heatsink to expose the thermal pad.
      • Align your heatsink over the CPU and place it straight down onto the Mainboard.
      • The thermal pad needs to go through a few thermal cycles before it gets to full performance.
      Ask FixBot
    5. Framework Laptop 16 CPU Heatsink Installation, Install the CPU Heatsink screws: step 5, image 1 of 2 Framework Laptop 16 CPU Heatsink Installation, Install the CPU Heatsink screws: step 5, image 2 of 2
      • Use your Framework Screwdriver to install or tighten the T5 Torx screws securing the CPU Heatsink:
      • Tighten the captive screw above the primary SSD.
      • Tighten the captive screws directly over the CPU in reverse order from 4–1.
      • Install the two 2.0 mm‑long screws along the top corners of the Mainboard.
      Ask FixBot
Alex Diaz-Kokaisl
250,095 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 15
All Time: 81
