While supporting the Top Cover with one hand, use your Framework Screwdriver to remove the four 3.9 mm‑long screws on each hinge connected to the Bottom Cover (8 total).
Lift up the interposer door to reveal the screw underneath.
Use your Framework Screwdriver to remove the six 2.0 mm‑long T5 Torx screws securing the Mainboard.
Use your fingers to lift the bottom edge of the Mainboard enough to grip its edges.
Lift the Mainboard off its alignment pegs and remove it.
