Framework Laptop 16 Bottom Cover Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Bottom Cover Installation, Bottom Cover information: step 1, image 1 of 2 Framework Laptop 16 Bottom Cover Installation, Bottom Cover information: step 1, image 2 of 2
      • The replacement Bottom Cover comes with pre-installed screws for the hinge, Mainboard, and the speakers. During reassembly, use those screws to replace your old ones.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Installation, Remove the liner: step 2, image 1 of 3 Framework Laptop 16 Bottom Cover Installation, Remove the liner: step 2, image 2 of 3 Framework Laptop 16 Bottom Cover Installation, Remove the liner: step 2, image 3 of 3
      • If you have a secondary SSD installed, remove the blue liner on the thermal pad.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Installation, Place the Mainboard: step 3, image 1 of 2 Framework Laptop 16 Bottom Cover Installation, Place the Mainboard: step 3, image 2 of 2
      • Place the Mainboard into the laptop and onto its alignment pegs.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Installation, Install the Mainboard screws: step 4, image 1 of 2 Framework Laptop 16 Bottom Cover Installation, Install the Mainboard screws: step 4, image 2 of 2
      • Use your Framework Screwdriver to install the six 2.0 mm‑long T5 Torx screws securing the Mainboard.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Installation, Place the Top Cover: step 5, image 1 of 2 Framework Laptop 16 Bottom Cover Installation, Place the Top Cover: step 5, image 2 of 2
      • Place the Top Cover over Bottom Top Cover, making sure the hinges are slotted into their alignment pegs.
      Ask FixBot
    6. Framework Laptop 16 Bottom Cover Installation, Install the hinge screws: step 6, image 1 of 3 Framework Laptop 16 Bottom Cover Installation, Install the hinge screws: step 6, image 2 of 3 Framework Laptop 16 Bottom Cover Installation, Install the hinge screws: step 6, image 3 of 3
      • While supporting the Top Cover with one hand, use your Framework Screwdriver to install the four 3.9 mm‑long screws on each hinge connected to the Bottom Cover (8 total).
      Ask FixBot
Alex Diaz-Kokaisl
250,027 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 39
