Framework Laptop 16 Bezel Replacement
    1. Framework Laptop 16 Bezel Replacement, Create a gap: step 1, image 1 of 3 Framework Laptop 16 Bezel Replacement, Create a gap: step 1, image 2 of 3 Framework Laptop 16 Bezel Replacement, Create a gap: step 1, image 3 of 3
      • The bezel is secured with magnets.
      • Slide your fingernail under the inside edge of either bottom corner of the bezel.
      • Pull the bezel away from the screen to release the first few magnets.
      Ask FixBot
    2. Framework Laptop 16 Bezel Replacement, Remove the bezel: step 2, image 1 of 3 Framework Laptop 16 Bezel Replacement, Remove the bezel: step 2, image 2 of 3 Framework Laptop 16 Bezel Replacement, Remove the bezel: step 2, image 3 of 3
      • Lift the bezel around the perimeter of the screen until all of its magnets are released.
      • Remove the bezel.
      Ask FixBot
    1. Framework Laptop 16 Bezel Replacement, Install the bezel: step 3, image 1 of 3 Framework Laptop 16 Bezel Replacement, Install the bezel: step 3, image 2 of 3 Framework Laptop 16 Bezel Replacement, Install the bezel: step 3, image 3 of 3
      • Align the bezel over the perimeter of the display and let the magnets pull the bezel into place.
      • The bezel should "snap" into place. If it doesn't, realign it and make sure it sits flush with the display.
      Ask FixBot
    2. Framework Laptop 16 Bezel Replacement, Remove the plastic liners: step 4, image 1 of 2 Framework Laptop 16 Bezel Replacement, Remove the plastic liners: step 4, image 2 of 2
      • If there are any plastic liners covering the webcam and microphone, remove them.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
250,047 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 46
All Time: 352
