Framework Laptop 16 Antenna Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16 Antenna Installation, Remove the adhesive liner: step 1, image 1 of 2 Framework Laptop 16 Antenna Installation, Remove the adhesive liner: step 1, image 2 of 2
      • Remove the liner from the back of your replacement right antenna.
      • The right antenna has a white cable and has an R printed on its front.
      Ask FixBot
    2. Framework Laptop 16 Antenna Installation, Install the right antenna: step 2, image 1 of 3 Framework Laptop 16 Antenna Installation, Install the right antenna: step 2, image 2 of 3 Framework Laptop 16 Antenna Installation, Install the right antenna: step 2, image 3 of 3
      • Use your fingers to slide the right antenna into its slot on the Top Cover and press it into its alignment peg.
      Ask FixBot
    3. Framework Laptop 16 Antenna Installation, Install the right antenna screw: step 3, image 1 of 2 Framework Laptop 16 Antenna Installation, Install the right antenna screw: step 3, image 2 of 2
      • While keeping the antenna pressed into place, use your Framework Screwdriver to install the 2.4 mm‑long T5 Torx screw securing the right antenna.
      Ask FixBot
    4. Framework Laptop 16 Antenna Installation: step 4, image 1 of 3 Framework Laptop 16 Antenna Installation: step 4, image 2 of 3 Framework Laptop 16 Antenna Installation: step 4, image 3 of 3
      • Use the flat end of your Framework Screwdriver to press the copper film onto the Top Cover and adhere it.
      Ask FixBot
    5. Framework Laptop 16 Antenna Installation, Reroute the white cable: step 5, image 1 of 3 Framework Laptop 16 Antenna Installation, Reroute the white cable: step 5, image 2 of 3 Framework Laptop 16 Antenna Installation, Reroute the white cable: step 5, image 3 of 3
      • Use the flat end of your Framework Screwdriver, or your fingers, to press the white antenna cable into its clips at the top right corner of the Top Cover.
      Ask FixBot
    6. Framework Laptop 16 Antenna Installation: step 6, image 1 of 3 Framework Laptop 16 Antenna Installation: step 6, image 2 of 3 Framework Laptop 16 Antenna Installation: step 6, image 3 of 3
      • Repeat the previous step for the clips along the right edge of the Top Cover.
      Ask FixBot
    7. Framework Laptop 16 Antenna Installation, Remove the adhesive liner: step 7, image 1 of 2 Framework Laptop 16 Antenna Installation, Remove the adhesive liner: step 7, image 2 of 2
      • Remove the liner from the back of your replacement left antenna.
      • The left antenna has a black cable and has an L printed on its front.
      Ask FixBot
    8. Framework Laptop 16 Antenna Installation, Install the left antenna: step 8, image 1 of 3 Framework Laptop 16 Antenna Installation, Install the left antenna: step 8, image 2 of 3 Framework Laptop 16 Antenna Installation, Install the left antenna: step 8, image 3 of 3
      • Use your fingers to slide the left antenna into its slot on the Top Cover and press it into its alignment peg.
      Ask FixBot
    9. Framework Laptop 16 Antenna Installation, Install the left antenna screw: step 9, image 1 of 2 Framework Laptop 16 Antenna Installation, Install the left antenna screw: step 9, image 2 of 2
      • While keeping the antenna pressed into place, use your Framework Screwdriver to install the 2.4 mm‑long T5 Torx screw securing the left antenna.
      Ask FixBot
    10. Framework Laptop 16 Antenna Installation: step 10, image 1 of 3 Framework Laptop 16 Antenna Installation: step 10, image 2 of 3 Framework Laptop 16 Antenna Installation: step 10, image 3 of 3
      Ask FixBot
    11. Framework Laptop 16 Antenna Installation, Reroute the black cable: step 11, image 1 of 3 Framework Laptop 16 Antenna Installation, Reroute the black cable: step 11, image 2 of 3 Framework Laptop 16 Antenna Installation, Reroute the black cable: step 11, image 3 of 3
      • Use the flat end of your Framework Screwdriver, or your fingers, to press the black antenna cable into its clips at the top left corner of the Top Cover.
      Ask FixBot
    12. Framework Laptop 16 Antenna Installation: step 12, image 1 of 3 Framework Laptop 16 Antenna Installation: step 12, image 2 of 3 Framework Laptop 16 Antenna Installation: step 12, image 3 of 3
      • Repeat the previous step for the clips along the left edge of the Top Cover.
      Ask FixBot
Alex Diaz-Kokaisl
250,047 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 100
