Framework Laptop 13 Touchpad Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Touchpad Removal, Touchpad connector information: step 1, image 1 of 3 Framework Laptop 13 Touchpad Removal, Touchpad connector information: step 1, image 2 of 3 Framework Laptop 13 Touchpad Removal, Touchpad connector information: step 1, image 3 of 3
      • The next six steps show how to disconnect the three cables that are connected to the touchpad. Use this photo as a reference for where they're located:
      • Fingerprint Reader Cable
      • Keyboard Membrane Cable
      • Keyboard Backlight Cable
      • The replacement touchpad comes with a Touchpad Cable pre‑installed, so you don't have to disconnect it.
      Ask FixBot
    2. Framework Laptop 13 Touchpad Removal, Disconnect the Fingerprint Reader Cable: step 2, image 1 of 2 Framework Laptop 13 Touchpad Removal, Disconnect the Fingerprint Reader Cable: step 2, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Fingerprint Reader ZIF connector on the touchpad.
      Ask FixBot
    3. Framework Laptop 13 Touchpad Removal: step 3, image 1 of 2 Framework Laptop 13 Touchpad Removal: step 3, image 2 of 2
      • Use your fingers to lightly grip the Fingerprint Reader Cable and slide it straight out of its socket.
      Ask FixBot
    4. Framework Laptop 13 Touchpad Removal, Disconnect the keyboard membrane: step 4, image 1 of 2 Framework Laptop 13 Touchpad Removal, Disconnect the keyboard membrane: step 4, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the keyboard membrane ZIF connector on the touchpad.
      Ask FixBot
    5. Framework Laptop 13 Touchpad Removal: step 5, image 1 of 2 Framework Laptop 13 Touchpad Removal: step 5, image 2 of 2
      • Use your fingers to lightly grip the keyboard membrane cable and slide it straight out of its socket.
      Ask FixBot
    6. Framework Laptop 13 Touchpad Removal, Disconnect the keyboard backlight cable: step 6, image 1 of 2 Framework Laptop 13 Touchpad Removal, Disconnect the keyboard backlight cable: step 6, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the keyboard backlight ZIF connector on the touchpad.
      Ask FixBot
    7. Framework Laptop 13 Touchpad Removal: step 7, image 1 of 2 Framework Laptop 13 Touchpad Removal: step 7, image 2 of 2
      • Use your fingers to lightly grip the keyboard backlight cable and slide it straight out of its socket.
      Ask FixBot
    8. Framework Laptop 13 Touchpad Removal, Remove the touchpad bracket screws: step 8, image 1 of 2 Framework Laptop 13 Touchpad Removal, Remove the touchpad bracket screws: step 8, image 2 of 2
      • Use your Framework Screwdriver to remove the two 1.8 mm‑long Phillips screws securing the touchpad bracket.
      Ask FixBot
    9. Framework Laptop 13 Touchpad Removal, Remove the touchpad bracket: step 9, image 1 of 3 Framework Laptop 13 Touchpad Removal, Remove the touchpad bracket: step 9, image 2 of 3 Framework Laptop 13 Touchpad Removal, Remove the touchpad bracket: step 9, image 3 of 3
      • Lift the touchpad bracket towards the top of the Input Cover to release its two metal clips.
      • Remove the touchpad bracket.
      Ask FixBot
    10. Framework Laptop 13 Touchpad Removal, Remove the touchpad screws: step 10, image 1 of 2 Framework Laptop 13 Touchpad Removal, Remove the touchpad screws: step 10, image 2 of 2
      • Use your Framework Screwdriver to remove the two 1.8 mm‑long Phillips screws securing the touchpad.
      Ask FixBot
    11. Framework Laptop 13 Touchpad Removal, Remove the touchpad: step 11, image 1 of 3 Framework Laptop 13 Touchpad Removal, Remove the touchpad: step 11, image 2 of 3 Framework Laptop 13 Touchpad Removal, Remove the touchpad: step 11, image 3 of 3
      • Use your fingers to lift the bottom edge of the touchpad and pull it towards the bottom edge of the Input Cover to release its two metal clips.
      • Remove the touchpad.
      Ask FixBot
Alex Diaz-Kokaisl
249,970 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 74
