Framework Laptop 13 Touchpad Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Touchpad Installation, Touchpad information: step 1, image 1 of 3 Framework Laptop 13 Touchpad Installation, Touchpad information: step 1, image 2 of 3 Framework Laptop 13 Touchpad Installation, Touchpad information: step 1, image 3 of 3
      • Your replacement touchpad comes with a protective film that helps center the module during reassembly. Do not remove it until you fully reassemble the laptop.
      • Fold the six plastic tabs over the edge of the Touchpad.
      Ask FixBot
    2. Framework Laptop 13 Touchpad Installation, Place the touchpad: step 2, image 1 of 3 Framework Laptop 13 Touchpad Installation, Place the touchpad: step 2, image 2 of 3 Framework Laptop 13 Touchpad Installation, Place the touchpad: step 2, image 3 of 3
      Ask FixBot
    3. Framework Laptop 13 Touchpad Installation, Install the touchpad screws: step 3, image 1 of 3 Framework Laptop 13 Touchpad Installation, Install the touchpad screws: step 3, image 2 of 3 Framework Laptop 13 Touchpad Installation, Install the touchpad screws: step 3, image 3 of 3
      • While holding the touchpad in place, use your Framework Screwdriver to install the two 1.8 mm‑long Phillips screws securing the top of the touchpad.
      Ask FixBot
    4. Framework Laptop 13 Touchpad Installation, Place the touchpad bracket: step 4, image 1 of 2 Framework Laptop 13 Touchpad Installation, Place the touchpad bracket: step 4, image 2 of 2
      • Slide the metal clips on the touchpad bracket into its slots on the Input Cover.
      • Press the bracket flat onto the Input Cover.
      Ask FixBot
    5. Framework Laptop 13 Touchpad Installation, Install the touchpad bracket screws: step 5, image 1 of 2 Framework Laptop 13 Touchpad Installation, Install the touchpad bracket screws: step 5, image 2 of 2
      • Use your Framework Screwdriver to install the two 1.8 mm‑long Phillips screws securing the touchpad bracket.
      Ask FixBot
    6. Framework Laptop 13 Touchpad Installation, Connect the keyboard backlight cable: step 6, image 1 of 2 Framework Laptop 13 Touchpad Installation, Connect the keyboard backlight cable: step 6, image 2 of 2
      • Slide the keyboard backlight cable straight into its socket.
      Ask FixBot
    7. Framework Laptop 13 Touchpad Installation: step 7, image 1 of 2 Framework Laptop 13 Touchpad Installation: step 7, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the keyboard backlight ZIF connector.
      Ask FixBot
    8. Framework Laptop 13 Touchpad Installation, Connect the keyboard membrane: step 8, image 1 of 2 Framework Laptop 13 Touchpad Installation, Connect the keyboard membrane: step 8, image 2 of 2
      • Slide the keyboard membrane cable straight into its socket.
      Ask FixBot
    9. Framework Laptop 13 Touchpad Installation: step 9, image 1 of 2 Framework Laptop 13 Touchpad Installation: step 9, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the keyboard membrane ZIF connector.
      Ask FixBot
    10. Framework Laptop 13 Touchpad Installation, Connect the Fingerprint Reader Cable: step 10, image 1 of 2 Framework Laptop 13 Touchpad Installation, Connect the Fingerprint Reader Cable: step 10, image 2 of 2
      • Slide the Fingerprint Reader Cable straight into its socket.
      Ask FixBot
    11. Framework Laptop 13 Touchpad Installation: step 11, image 1 of 2 Framework Laptop 13 Touchpad Installation: step 11, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Fingerprint Reader Cable ZIF connector.
      Ask FixBot
Alex Diaz-Kokaisl
249,976 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 52
