Framework Laptop 13 Pro Storage Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Storage Removal, Remove the SSD screw: step 1, image 1 of 2 Framework Laptop 13 Pro Storage Removal, Remove the SSD screw: step 1, image 2 of 2
      • Use your Framework Screwdriver to remove the 3.0 mm‑long T5 Torx screw securing the SSD.
      • The SSD might pop up at a shallow angle when you remove the screw.
      Ask FixBot
    2. Framework Laptop 13 Pro Storage Removal, Remove the SSD: step 2, image 1 of 2 Framework Laptop 13 Pro Storage Removal, Remove the SSD: step 2, image 2 of 2
      • Grip the end of the SSD with the screw hole and slide it out of its socket.
      • Remove the SSD.
      Ask FixBot
Alex Diaz-Kokaisl
250,018 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 16
