Framework Laptop 13 Pro Memory Installation (SODIMM)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Memory Installation (SODIMM), Install the DDR5 Memory: step 1, image 1 of 3 Framework Laptop 13 Pro Memory Installation (SODIMM), Install the DDR5 Memory: step 1, image 2 of 3 Framework Laptop 13 Pro Memory Installation (SODIMM), Install the DDR5 Memory: step 1, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • While holding up the black flap covering the left memory module, orient the module with its label facing down and align the gold contacts with the left socket.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 13 Pro Memory Installation (SODIMM): step 2, image 1 of 3 Framework Laptop 13 Pro Memory Installation (SODIMM): step 2, image 2 of 3 Framework Laptop 13 Pro Memory Installation (SODIMM): step 2, image 3 of 3
      • Repeat the previous step for the right socket, except orient the module so its label is facing upward.
      Ask FixBot
Alex Diaz-Kokaisl
250,018 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 14
