Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Loosen the LPCAMM2 Memory Cover: step 1, image 1 of 2 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Loosen the LPCAMM2 Memory Cover: step 1, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
      Ask FixBot
    2. Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Remove the LPCAMM2 Memory Cover: step 2, image 1 of 2 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Remove the LPCAMM2 Memory Cover: step 2, image 2 of 2
      • Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
      Ask FixBot
    3. Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Remove the LPCAMM2 Memory Spacer: step 3, image 1 of 2 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Remove the LPCAMM2 Memory Spacer: step 3, image 2 of 2
      • Remove the LPCAMM2 Memory Spacer and recycle it.
      • Avoid touching the Interposer below the Spacer. If the Interposer accidentally shifts, grab it by its edges to place it back into its alignment pegs.
      • Make sure there's no dust or debris on top of the Interposer before continuing.
      Ask FixBot
    4. Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Place the LPCAMM2 Memory: step 4, image 1 of 3 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Place the LPCAMM2 Memory: step 4, image 2 of 3 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Place the LPCAMM2 Memory: step 4, image 3 of 3
      • Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
      Ask FixBot
    5. Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Place the LPCAMM2 Memory Cover: step 5, image 1 of 2 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Place the LPCAMM2 Memory Cover: step 5, image 2 of 2
      • Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
      • The cover should lay flat when aligned properly.
      Ask FixBot
    6. Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Tighten the LPCAMM2 Memory Cover: step 6, image 1 of 2 Framework Laptop 13 Pro Memory (LPCAMM) Installation (Mainboard), Tighten the LPCAMM2 Memory Cover: step 6, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
      • Make sure the screws are snug enough to create proper contact between the memory and the Mainboard.
      Ask FixBot
Alex Diaz-Kokaisl
250,047 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 17
