Framework Laptop 13 Pro Mainboard Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Mainboard Removal, Disconnect the Speakers: step 1, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Disconnect the Speakers: step 1, image 2 of 2
      • Use your fingers to grip the edges of the Speakers Cable connector.
      • Pull the connector straight out of its socket to disconnect it.
      Ask FixBot
    2. Framework Laptop 13 Pro Mainboard Removal, Disconnect the Audio Board: step 2, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Disconnect the Audio Board: step 2, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Audio Board ZIF connector on the Mainboard.
      Ask FixBot
    3. Framework Laptop 13 Pro Mainboard Removal: step 3, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal: step 3, image 2 of 2
      • Use your fingers to lightly grip the Audio Board cable and slide it straight out of its socket.
      Ask FixBot
    4. Framework Laptop 13 Pro Mainboard Removal, Disconnect the Display eDP Cable: step 4, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Disconnect the Display eDP Cable: step 4, image 2 of 2
      • Grip the Display eDP Cable connector by its pull tab and lift up to disconnect it.
      Ask FixBot
    5. Framework Laptop 13 Pro Mainboard Removal, Disconnect the Webcam Cable: step 5, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Disconnect the Webcam Cable: step 5, image 2 of 2
      • Repeat the previous step for the Webcam Cable connector.
      Ask FixBot
    6. Framework Laptop 13 Pro Mainboard Removal, Lift the Antenna Cables: step 6, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Lift the Antenna Cables: step 6, image 2 of 2
      • Use your fingers or the flat end of the Framework Screwdriver to lift the two Antenna Cables out of their clips on the Mainboard.
      Ask FixBot
    7. Framework Laptop 13 Pro Mainboard Removal, Loosen the Wi-Fi module screw: step 7, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Loosen the Wi-Fi module screw: step 7, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi module.
      • The module might pop up at a shallow angle when you loosen the screw.
      Ask FixBot
    8. Framework Laptop 13 Pro Mainboard Removal, Disconnect the Wi-Fi module: step 8, image 1 of 3 Framework Laptop 13 Pro Mainboard Removal, Disconnect the Wi-Fi module: step 8, image 2 of 3 Framework Laptop 13 Pro Mainboard Removal, Disconnect the Wi-Fi module: step 8, image 3 of 3
      • Grip the end of the Wi-Fi module with the screw hole and slide it out of its socket.
      • Don't pull the module too far from its socket, as it's still connected by two cables.
      • Keep the plastic bracket attached to the module to prevent the cables from disconnecting.
      • Position the Wi-Fi module to the right of the laptop to keep it out of the way of the Mainboard.
      Ask FixBot
    9. Framework Laptop 13 Pro Mainboard Removal, Remove the Mainboard screws: step 9, image 1 of 2 Framework Laptop 13 Pro Mainboard Removal, Remove the Mainboard screws: step 9, image 2 of 2
      • Use your Framework Screwdriver to remove the five 1.5 mm‑long T5 Torx screws securing the Mainboard.
      • Since these screws aren't captive, put them in a safe place.
      Ask FixBot
    10. Framework Laptop 13 Pro Mainboard Removal, Remove the Mainboard: step 10, image 1 of 3 Framework Laptop 13 Pro Mainboard Removal, Remove the Mainboard: step 10, image 2 of 3 Framework Laptop 13 Pro Mainboard Removal, Remove the Mainboard: step 10, image 3 of 3
      • Use your fingers to lift the bottom edge of the Mainboard enough to grip its edges.
      • Lift the Mainboard off its alignment pegs and remove it.
      Ask FixBot
Alex Diaz-Kokaisl
250,129 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 19
