Framework Laptop 13 Pro LPCAMM Cover Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro LPCAMM Cover Installation, Place the LPCAMM2 Memory Cover: step 1, image 1 of 2 Framework Laptop 13 Pro LPCAMM Cover Installation, Place the LPCAMM2 Memory Cover: step 1, image 2 of 2
      • Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
      • The cover should lay flat when aligned properly.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM Cover Installation, Tighten the LPCAMM2 Memory Cover: step 2, image 1 of 2 Framework Laptop 13 Pro LPCAMM Cover Installation, Tighten the LPCAMM2 Memory Cover: step 2, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
      • Make sure the screws are snug enough to create proper contact between the memory and the Mainboard.
      Ask FixBot
Alex Diaz-Kokaisl
250,135 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 27
