Framework Laptop 13 Pro Interposer Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Interposer Removal, Remove the LPCAMM2 Memory Interposer: step 1, image 1 of 3 Framework Laptop 13 Pro Interposer Removal, Remove the LPCAMM2 Memory Interposer: step 1, image 2 of 3 Framework Laptop 13 Pro Interposer Removal, Remove the LPCAMM2 Memory Interposer: step 1, image 3 of 3
      • Be extremely careful when handling the Interposer, as its pins can break easily. Only grip its edges to avoid touching its pins.
      • Use a fingernail to lift up the bottom edge of the Interposer until you can grip its edges with your fingers.
      • Lift the Interposer straight off its alignment pegs and remove it.
      • Avoid pressing or bending the pins against the Mainboard as you lift.
      Ask FixBot
Alex Diaz-Kokaisl
249,976 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 49
