Framework Laptop 13 Pro Input Cover Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Input Cover Removal, Loosen the Input Cover screws: step 1, image 1 of 2 Framework Laptop 13 Pro Input Cover Removal, Loosen the Input Cover screws: step 1, image 2 of 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      Ask FixBot
    2. Framework Laptop 13 Pro Input Cover Removal, Lift the Input Cover: step 2, image 1 of 2 Framework Laptop 13 Pro Input Cover Removal, Lift the Input Cover: step 2, image 2 of 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
      Ask FixBot
    3. Framework Laptop 13 Pro Input Cover Removal, Flip over the Input Cover: step 3, image 1 of 2 Framework Laptop 13 Pro Input Cover Removal, Flip over the Input Cover: step 3, image 2 of 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Ask FixBot
    4. Framework Laptop 13 Pro Input Cover Removal, Disconnect the Touchpad Cable: step 4, image 1 of 2 Framework Laptop 13 Pro Input Cover Removal, Disconnect the Touchpad Cable: step 4, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Ask FixBot
    5. Framework Laptop 13 Pro Input Cover Removal, Remove the Input Cover: step 5, image 1 of 2 Framework Laptop 13 Pro Input Cover Removal, Remove the Input Cover: step 5, image 2 of 2
      • Remove the Input Cover.
      Ask FixBot
Alex Diaz-Kokaisl
250,059 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
