Framework Laptop 13 Pro Input Cover Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Input Cover Installation, Position the Input Cover: step 1, image 1 of 2 Framework Laptop 13 Pro Input Cover Installation, Position the Input Cover: step 1, image 2 of 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    2. Framework Laptop 13 Pro Input Cover Installation, Connect the Touchpad Cable: step 2, image 1 of 2 Framework Laptop 13 Pro Input Cover Installation, Connect the Touchpad Cable: step 2, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
      Ask FixBot
    3. Framework Laptop 13 Pro Input Cover Installation, Place the Input Cover: step 3, image 1 of 2 Framework Laptop 13 Pro Input Cover Installation, Place the Input Cover: step 3, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    4. Framework Laptop 13 Pro Input Cover Installation: step 4, image 1 of 3 Framework Laptop 13 Pro Input Cover Installation: step 4, image 2 of 3 Framework Laptop 13 Pro Input Cover Installation: step 4, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    5. Framework Laptop 13 Pro Input Cover Installation, Reposition the laptop: step 5, image 1 of 1
      • Close the laptop and flip it over.
      Ask FixBot
    6. Framework Laptop 13 Pro Input Cover Installation, Tighten the Input Cover screws: step 6, image 1 of 2 Framework Laptop 13 Pro Input Cover Installation, Tighten the Input Cover screws: step 6, image 2 of 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
Alex Diaz-Kokaisl
250,018 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 28
