Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Unbox your Bottom Cover Upgrade Kit: step 1, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Unbox your Bottom Cover Upgrade Kit: step 1, image 2 of 2
      • Unbox your Bottom Cover Upgrade Kit and make sure you've received the following items:
      • Bottom Cover Kit
      • Keyboard
      • Input Cover Frame (including the Keyboard Bracket and Fingerprint Reader Cable)
      • Speaker Kit
      • Battery
      • Audio Board Kit
      • Fastener Kit – Input Cover and Keyboard (only the Keyboard and Keyboard Bracket screws are needed—the rest can be kept as spares)
      Ask FixBot
    2. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Separate the Speakers: step 2, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Separate the Speakers: step 2, image 2 of 2
      • Separate the Speakers from each other if they're attached.
      Ask FixBot
    3. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Speakers: step 3, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Speakers: step 3, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Speakers: step 3, image 3 of 3
      • Place the left Speaker into its slot on the Bottom Cover, making sure it's aligned with its screw posts and threaded through its alignment peg.
      • The left Speaker has an "L" labeled on it.
      Ask FixBot
    4. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 4, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 4, image 2 of 2
      • Repeat the previous step for the right Speaker.
      • The right Speaker has an "R" labeled on it.
      Ask FixBot
    5. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Speaker screws: step 5, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Speaker screws: step 5, image 2 of 2
      • Use your Framework Screwdriver to tighten the two T5 Torx screws on each Speaker (4 total).
      Ask FixBot
    6. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Route the Speaker Cables: step 6, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Route the Speaker Cables: step 6, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Route the Speaker Cables: step 6, image 3 of 3
      • Starting from the right Speaker, press the speaker cable into its metal and plastic clips on the Bottom Cover.
      • Pull the cable taut against the Bottom Cover as you do this, as you'll need slack along the left edge.
      Ask FixBot
    7. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 7, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 7, image 2 of 2
      • If you're having difficulty pressing the speaker cable into its plastic clips, twist the cable so it's vertical and use the flat end of your Framework Screwdriver to press it down.
      Ask FixBot
    8. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 8, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 8, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 8, image 3 of 3
      • Repeat the previous two steps for the section of Speaker Cable near the left Speaker.
      Ask FixBot
    9. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Remove the liner: step 9, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Remove the liner: step 9, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Remove the liner: step 9, image 3 of 3
      • Remove the blue liner from the black tape near the left Speaker.
      Ask FixBot
    10. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Separate the tape: step 10, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Separate the tape: step 10, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Separate the tape: step 10, image 3 of 3
      • Slide the flat end of your Framework Screwdriver under the black tape and separate one of its long edges from the Chassis.
      Ask FixBot
    11. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Adhere the Speaker Cable: step 11, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Adhere the Speaker Cable: step 11, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Adhere the Speaker Cable: step 11, image 3 of 3
      • While holding the tape out of the way, lay the Speaker Cable into the channel underneath it.
      • Press the tape over the Speaker Cable to adhere it to the Chassis.
      Ask FixBot
    12. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Check the Battery socket: step 12, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Check the Battery socket: step 12, image 2 of 2
      • Before continuing, check the pins on the Battery socket and make sure they aren't bent.
      • If any of the pins are bent, reach out to Framework Support.
      Ask FixBot
    13. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Mainboard: step 13, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Mainboard: step 13, image 2 of 2
      • Grab the Mainboard by its edges and place it into the Bottom Cover and onto its alignment pegs.
      Ask FixBot
    14. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Mainboard screws: step 14, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Mainboard screws: step 14, image 2 of 2
      • Use your Framework Screwdriver to install the five 1.5 mm‑long T5 Torx screws securing the Mainboard.
      Ask FixBot
    15. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Insert the Audio Board: step 15, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Insert the Audio Board: step 15, image 2 of 2
      • Angle the left edge of the Audio Board downward and slide the headphone jack through its hole in the Bottom Cover.
      • Align the screw hole in the Audio Board with its post and press it flat to the Bottom Cover.
      Ask FixBot
    16. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Audio Board screw: step 16, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Audio Board screw: step 16, image 2 of 2
      • Use your Framework Screwdriver to install the 3.0 mm‑long T5 Torx screw securing the Audio Board.
      Ask FixBot
    17. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 17, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 17, image 2 of 2
      • Insert the Battery into its cutout, making sure its plastic tabs are slotted into the Bottom Cover.
      Ask FixBot
    18. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Battery screws: step 18, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Battery screws: step 18, image 2 of 2
      • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the Battery.
      Ask FixBot
    19. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Top Cover: step 19, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Top Cover: step 19, image 2 of 2
      • Place the Top Cover on its two sets of alignment pegs on the Bottom Cover.
      • Make sure all of the cables are above the Bottom Cover before continuing.
      Ask FixBot
    20. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Hinge screws: step 20, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Hinge screws: step 20, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Hinge screws: step 20, image 3 of 3
      • While supporting the Top Cover with one hand, use your Framework Screwdriver to install two 4.0 mm‑long T5 Torx screws on each Hinge connected to the Bottom Cover (four total).
      Ask FixBot
    21. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Display eDP Cable: step 21, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Display eDP Cable: step 21, image 2 of 2
      • Place the Display eDP Cable into its slot on the Bottom Cover.
      Ask FixBot
    22. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Display eDP Cable: step 22, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Display eDP Cable: step 22, image 2 of 2
      • Press the Display eDP Cable connector straight down into its socket to connect it.
      Ask FixBot
    23. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Adhere the grounding tape: step 23, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Adhere the grounding tape: step 23, image 2 of 2
      • Press the grounding tape onto the left Hinge to adhere it.
      Ask FixBot
    24. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Audio Board: step 24, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Audio Board: step 24, image 2 of 2
      • Slide the Audio Board cable straight into its socket.
      Ask FixBot
    25. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 25, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 25, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Audio Board ZIF connector.
      Ask FixBot
    26. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Speakers: step 26, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Speakers: step 26, image 2 of 2
      • Slide the Speaker connector straight into its socket.
      Ask FixBot
    27. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Webcam Cable: step 27, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Webcam Cable: step 27, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Webcam Cable: step 27, image 3 of 3
      • Use your finger to guide the Webcam Cable into its metal pegs on the Bottom Cover.
      • Refer to this photo for how the cable should look when properly routed.
      Ask FixBot
    28. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Webcam Cable: step 28, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Webcam Cable: step 28, image 2 of 2
      • Press the Webcam Cable connector straight down into its socket to connect it.
      Ask FixBot
    29. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Antenna Cables: step 29, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Antenna Cables: step 29, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Antenna Cables: step 29, image 3 of 3
      • Use your finger to press the Antenna Cables into their metal clip on the Bottom Cover.
      • Rotate the cables around the raised corner at the top right of the Mainboard so they point towards the Wi-Fi module.
      • Refer to this photo for how the cables should look when properly routed.
      Ask FixBot
    30. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Loosen the Wi-Fi module cover screw: step 30, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Loosen the Wi-Fi module cover screw: step 30, image 2 of 2
      • The Bottom Cover comes with a pre-installed Wi-Fi Module cover. It's optional to swap your cover with this replacement.
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi module cover.
      Ask FixBot
    31. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Remove the cover: step 31, image 1 of 1
      • Remove the Wi-Fi module cover.
      Ask FixBot
    32. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Wi-Fi module: step 32, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Wi-Fi module: step 32, image 2 of 2
      • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    33. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reconnect the Wi-Fi module: step 33, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reconnect the Wi-Fi module: step 33, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reconnect the Wi-Fi module: step 33, image 3 of 3
      • If the Antenna Cables got accidentally disconnected, follow this step to reconnect them. Otherwise, skip this step to continue the guide normally.
      • Hold the Wi-Fi module down with your finger.
      • Position the black antenna cable connector over the Wi-Fi module's coaxial socket indicated by the black arrow.
      • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the white antenna cable.
      Ask FixBot
    34. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Wi-Fi module screw: step 34, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Wi-Fi module screw: step 34, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing the Wi-Fi module.
      Ask FixBot
    35. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Antenna Cables: step 35, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Antenna Cables: step 35, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reroute the Antenna Cables: step 35, image 3 of 3
      • Use the flat end of your Framework Screwdriver to press the two Antenna Cables into their rubber clips on the Mainboard.
      Ask FixBot
    36. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reconnect the Battery: step 36, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Reconnect the Battery: step 36, image 2 of 2
      • Use your fingers to align the Battery connector with its socket and slide it straight in to reconnect the Battery.
      Ask FixBot
    37. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Keyboard: step 37, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Keyboard: step 37, image 2 of 2
      • Place the Keyboard into its cutout in the Top Cover.
      Ask FixBot
    38. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Keyboard screws: step 38, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Keyboard screws: step 38, image 2 of 2
      • Use your Framework Screwdriver to install the forty-six 1.2 mm‑long black PH0 screws securing the Keyboard.
      • The screw holes for the Keyboard are labeled with "KB" and an arrow pointing to them.
      Ask FixBot
    39. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Keyboard Bracket: step 39, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Keyboard Bracket: step 39, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Keyboard Bracket: step 39, image 3 of 3
      • Place the Keyboard Bracket onto its alignment pegs.
      Ask FixBot
    40. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Keyboard Bracket screws: step 40, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Keyboard Bracket screws: step 40, image 2 of 2
      • Use your Framework Screwdriver to install the twenty 1.3 mm‑long silver PH0 screws securing the Keyboard Bracket.
      Ask FixBot
    41. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Unlock the Fingerprint Reader: step 41, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Unlock the Fingerprint Reader: step 41, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Fingerprint Reader ZIF connector located on the Fingerprint Reader board.
      Ask FixBot
    42. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Fingerprint Reader Cable: step 42, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Fingerprint Reader Cable: step 42, image 2 of 2
      • Slide the Fingerprint Reader Cable straight into its socket.
      Ask FixBot
    43. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 43, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 43, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Fingerprint Reader ZIF connector.
      Ask FixBot
    44. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 44, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 44, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 44, image 3 of 3
      • Repeat the previous three steps to connect the Fingerprint Reader Cable on the Hub Board.
      Ask FixBot
    45. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Position the Input Cover: step 45, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Position the Input Cover: step 45, image 2 of 2
      • Your old Input Cover is not compatible—only use the new one.
      • Position the Input Cover, keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    46. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Touchpad Cable: step 46, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Connect the Touchpad Cable: step 46, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    47. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Input Cover: step 47, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Place the Input Cover: step 47, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    48. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 48, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 48, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 48, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    49. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Input Cover screws: step 49, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Tighten the Input Cover screws: step 49, image 2 of 2
      • Close the laptop and flip it over.
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
    50. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Expansion Cards: step 50, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Expansion Cards: step 50, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Install the Expansion Cards: step 50, image 3 of 3
      • For Expansion Card compatibility, check here.
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latch to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      • Repeat for the remaining Expansion Cards.
      Ask FixBot
    51. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 51, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation: step 51, image 2 of 2
      • Use your finger to flip both latches and lock the rows of Expansion Cards.
      Ask FixBot
    52. Framework Laptop 13 Pro Bottom Cover Upgrade Kit Installation, Update the software: step 52, image 1 of 1
      • You've finished upgrading your Framework Laptop! Check out this page to update to the latest drivers, firmware, and software.
      • You'll need to update to the latest BIOS for the battery to reach full capacity.
      Ask FixBot
Alex Diaz-Kokaisl
250,162 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
