Framework Laptop 13 Pro Battery Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Battery Removal, Disconnect the Battery: step 1, image 1 of 2 Framework Laptop 13 Pro Battery Removal, Disconnect the Battery: step 1, image 2 of 2
      • When disconnecting the Battery, make sure you slide its connector straight out of its socket or else you risk bending the socket's pins.
      • Use your fingers to grip the edges of the Battery connector and slide it straight out of its socket to disconnect the Battery.
      Ask FixBot
    2. Framework Laptop 13 Pro Battery Removal, Loosen the Battery screws: step 2, image 1 of 2 Framework Laptop 13 Pro Battery Removal, Loosen the Battery screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the Battery.
      Ask FixBot
    3. Framework Laptop 13 Pro Battery Removal, Remove the Battery: step 3, image 1 of 2 Framework Laptop 13 Pro Battery Removal, Remove the Battery: step 3, image 2 of 2
      • Only handle the Battery by its plastic frame, making sure you don't bend or puncture it.
      • Lift the Battery towards the top edge of the laptop to slide its plastic tabs out of the Bottom Cover.
      • Remove the Battery.
      Ask FixBot
Alex Diaz-Kokaisl
250,129 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 15
