Framework Laptop 13 Pro Battery Reconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Pro Battery Reconnect, Check the Battery socket: step 1, image 1 of 2 Framework Laptop 13 Pro Battery Reconnect, Check the Battery socket: step 1, image 2 of 2
      • Before continuing, check the pins on the Battery socket and make sure they aren't bent.
      • If any of the pins are bent, reach out to Framework Support.
      Ask FixBot
    2. Framework Laptop 13 Pro Battery Reconnect, Reconnect the Battery: step 2, image 1 of 2 Framework Laptop 13 Pro Battery Reconnect, Reconnect the Battery: step 2, image 2 of 2
      • Use your fingers to align the Battery connector with its socket and slide it straight in to reconnect the Battery.
      Ask FixBot
Alex Diaz-Kokaisl
250,105 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 22
