Insert the Battery into its cutout, making sure its plastic tabs are slotted into the Bottom Cover.
Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the Battery.
Before continuing, check the pins on the Battery socket and make sure they aren't bent.
Use your fingers to align the Battery connector with its socket and slide it straight in to reconnect the Battery.
