Framework Laptop 13 Memory Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Memory Removal, Remove the memory: step 1, image 1 of 3 Framework Laptop 13 Memory Removal, Remove the memory: step 1, image 2 of 3 Framework Laptop 13 Memory Removal, Remove the memory: step 1, image 3 of 3
      • Depending on your Mainboard's generation, you might not have black flaps covering your memory.
      • While holding up the black flap covering the left memory module, push the two metal arms on each side of the module outward until they disengage and the module pops up at a shallow angle.
      • Slide the memory module out of its socket and remove it.
      Ask FixBot
    2. Framework Laptop 13 Memory Removal: step 2, image 1 of 3 Framework Laptop 13 Memory Removal: step 2, image 2 of 3 Framework Laptop 13 Memory Removal: step 2, image 3 of 3
      • Repeat the previous step for the right module.
      Ask FixBot
Alex Diaz-Kokaisl
249,976 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8
