Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
Remove the LPCAMM2 Memory Spacer and recycle it.
Make sure there's no dust or debris on top of the Interposer before continuing.
Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
