Before continuing, check the Touchpad Cable's ZIF connector located on the back of the Touchpad:
Make sure the white line on the cable is parallel to and adjacent with the socket.
If the cable isn't inserted far enough, use the flat end of the Framework Screwdriver to flip up the black latch, reposition the cable, and lock the latch.
Position the Input Cover, Keyboard down, on top of the laptop so it just covers the battery.
Insert your finger into the Touchpad Cable press connector loop.
Align the press connector over its socket and press down with your finger.
Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
