Framework Laptop 13 Battery Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Battery Installation, Install the Battery: step 1, image 1 of 2 Framework Laptop 13 Battery Installation, Install the Battery: step 1, image 2 of 2
      • Insert the Battery into its cutout, making sure its plastic tabs are slotted into the Bottom Cover.
      Ask FixBot
    2. Framework Laptop 13 Battery Installation, Tighten the Battery screws: step 2, image 1 of 2 Framework Laptop 13 Battery Installation, Tighten the Battery screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the Battery.
      Ask FixBot
    3. Framework Laptop 13 Battery Installation, Check the Battery socket: step 3, image 1 of 2 Framework Laptop 13 Battery Installation, Check the Battery socket: step 3, image 2 of 2
      • Before continuing, check the pins on the battery socket and make sure they aren't bent.
      • If any of the pins are bent, reach out to Framework Support.
      Ask FixBot
    4. Framework Laptop 13 Battery Installation, Reconnect the Battery: step 4, image 1 of 3 Framework Laptop 13 Battery Installation, Reconnect the Battery: step 4, image 2 of 3 Framework Laptop 13 Battery Installation, Reconnect the Battery: step 4, image 3 of 3
      • Use your fingers to align the battery connector with its socket and slide it straight in to reconnect the battery.
      Ask FixBot
Alex Diaz-Kokaisl
249,970 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 54
