Framework Laptop 13 Battery Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 13 Battery Disconnect, Disconnect the Battery: step 1, image 1 of 2 Framework Laptop 13 Battery Disconnect, Disconnect the Battery: step 1, image 2 of 2
      • When disconnecting the Battery, make sure you slide its connector straight out of its socket or else you risk bending the socket's pins.
      • Use your fingers to grip the edges of the Battery connector and slide it straight out of its socket to disconnect the Battery.
      Ask FixBot
Alex Diaz-Kokaisl
250,047 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 10
