Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
Use your fingers to slide the Wi-Fi module cover straight off the bottom of the module.
Remove the cover.
Press and hold the Wi-Fi module down with your fingers.
Use your fingers to grip the white antenna cable, as close to the metal head as possible.
Gently lift the connector straight up to disconnect the white antenna cable.
Repeat the procedure with the black antenna cable.
Grip the Wi-Fi module by its edges and pull it straight out of its socket.
Remove the Wi-Fi module.
